Hi
Can anyone tell me why i`ve got this result in my .idw. My 3d is looking fine, mean while my plate in my .idw seems to be breaked at its corner. I tried to see if i could selected. But with no result. I can select hte two lines connected to it. But the made up line is not. Is it fixable?
Solved by Curtis_Waguespack. Go to Solution.
Can you post the actual Inventor files?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi Rasckel,
It looks to me like maybe your detail boundary (or a breakout view boundary) is clipping the corner of your part, and that's where the extra line is coming from.
I hope this helps.
Curtis
Thanks Curtis
You where absolutely right. And i'm a bit embarrassed that i didn't see it sooner.
