Good question. We are struggling with this exact thing now. Although the
fasteners are common parts that are used throughout the assembly, they do
put a strain on the resources if you have a large number of them. Even if
you apply design views to turn them off, from what I have been told, they
are still loaded into memory. In my case the fasteners are required so I
can tell where interferences will be.
Putting the fasteners in a sub-assembly doesn't really benefit anything and
if the holes that the fasteners go in moves, the bolts will not move with
them. So you loose some fuctionality doing it that way.
I don't have a solution other than to use design views that turn them off.
It does help when you have to work in the iam's and you can do without them
being turned on. But, at some point you will have to turn them on and that
is when things get slow.
Same thing for the idw's. When you place the views in the drawings, if you
can do without showing the fasteners, then don't show them in the views.
Show them only when you need them.
IV R9, SP1
Dell PWS360, 2.6ghz, P4
2 Gb ram
nVidia FX1000
6.14.10.6808Driver
1260x1024x32 bit
"Travis (IV Pro 9)" wrote in
message news:416e973c$1_1@newsprd01...
> I have a question. Since we all know it isn't good practice to bog you
> assembly down with hundreds of bolts, due to sluggish performance issues
> when you get large numbers of parts in an assembly. My question is, then
how
> do all you guys perform a bolt count for your entire finished assembly. I
> mean, is there a way to recognize how many bolts you need without having
to
> go in and add them. And if their isn't a way, then how do you guys perform
> this task with your own finish assemblies? Do you manually count each? A
fix
> I thought about would be to have the ability to just count the tapped
holes
> in the assembly, giving a thread description next to quantity. The problem
> you then run into is how long of a bolt. Then I thought about having the
> ability to add a simple clean thread tag to the thread hole. Say for
> instance you have a hole in a plate that you have used the "Through all"
> selection on hole depth, how then do you recognize this bolt depth. My
idea
> of this would allow for a bolt depth tag note, that allows for a distance
to
> be included for bolt type counts. This is the only quick fix I could think
> of. I wouldn't even know where to begin at attempting this. This is just a
> problem that I encounter in Inventor and wanted you guys feedback on how
you
> go about doing this.
> Thanks,
> Travis
