There are situations where I have some warnings in Inventor that comes with the little red "+" sign that I can check what the error is and I can try to resolve the problem. But here I have a warning with no + sign and no any clue what the error is?
Where are the warnings and errors are hidden? is there any special file or something?
Solved by Cadmanto. Go to Solution.
Solved by cbenner. Go to Solution.
This is a derived part. I suspect the errors are in the parent file from which this was derived. Try opening that and see if the errors are defined. it may be that it just needs an update, or it could be that you have some unresolved parts.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi Chris,
No. I opened and checked the files. There are no errors and everything is updated.
My question is, if there is special file or place where I can see the details of errors/warnings?
I would call up that sub-assembly from your main assembly that you show and see if these parts are even still linked to this assembly. They might have lost their connection.
It might only need a rebuild as well.
Or as you say if the sub-assembly calls up fine, try replacing it in the main assembly.
Ist it possible you have another sub-assembly located somewhere else on your HD?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
