Inventor General
Valued Contributor
34mark713
Message 1 of 6 (162 Views)
Warning if saving as .STL file in INV 2011..
162 Views, 5 Replies
05-10-2012 07:13 AM
  Just thought I'd pass this on so someone else will not make the same mistake.  We modeled parts in inches.  We save as copy to an .STL file to get SLA prototypes made.  The parts came back 2.54 times bigger than needed.  Reason is the default setting for saving as .STL files is Centimeters....  Not sure why Autodesk did this....but yes I understand it's not their fault, we should have checked under options and changed it to inches.....we just assumed that you model in inches, it would save as in inches....See what happens when you assume....
  Any ways...hopefully I have save someone some time and money....
Mark
Valued Mentor
GSE_Dan_A
Message 2 of 6 (159 Views)
Re: Warning if saving as .STL file in INV 2011..
05-10-2012 07:20 AM in reply to: 34mark713
Units to Change
Just in case people were wondering where this option is...
GSE Consultants Inc.
Windsor, ON. Canada
*Expert Elite*
mcgyvr
Message 3 of 6 (153 Views)
05-10-2012 07:40 AM in reply to: GSE_Dan_A
yep autodesk broke this a little while back and frankly should get stuck with the bill for the scrapped parts anytime this happens.
It applies to 2012 also and probably 2013 too.
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Valued Contributor
34mark713
Message 4 of 6 (131 Views)
05-10-2012 10:04 AM in reply to: 34mark713
LOL...sounds great!!   Tell me where to send the bill....
*Expert Elite*
JDMather
Message 5 of 6 (125 Views)
05-10-2012 10:43 AM in reply to: 34mark713
Since this bill will likely go unpaid - you can at least use this issue for justifying your work time spent here
http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=location&location=forum-board%3A7...
The user community can save you a lot of money and headaches.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
mcgyvr
Message 6 of 6 (117 Views)
05-10-2012 12:55 PM in reply to: JDMather
Except you obviously need to know about it and unless you read every post on this board you have no way of knowing all the little issues/bugs related to Inventor..
Thats why is a shame that simple bugs like this can be carried over from release to release and nothing is done about it year after year.
Windows 7 64 bit
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
