Using the weld calculator in inventor 14 is it possible to create a report similar to the fea analysis.At the moment after the initial calculation has been done
any output does seem to dissapear to some obscure folder.
Regards
Solved by Curtis_Waguespack. Go to Solution.
Solved by blair. Go to Solution.
Hi methoni,
When you click the Results button, you get the report in an *.htm file, you can then sprint that as a PDF file if you have CutePDF or something similar installed? Other than that I don't know of anything other than what blair suggests.
I hope this helps.
Curtis
Hello Blair
Tried your approach and that works but also noticed that little box to the right ,clicked on that and that gives me the results read out,this is what i was looking for as the saying goes " could,nt see the wood for the trees"
Regards
