Inventor General
New Member
Message 1 of 4 (146 Views)
Accepted Solution
View updates
146 Views, 3 Replies
05-04-2012 05:08 AM
Hallo there.
Is there a way to stop my drawing views from updating when I make a change to my assembly? I have assemblys of boxes that I need to make different views from but everytime I open the door to show an inside view it screws up my other views.
Regards
Bobeep
*Expert Elite*
mrattray
Message 2 of 4 (144 Views)
Re: View updates
05-04-2012 05:13 AM in reply to: Bobeep
I think you need to do some reading about view representations.
Mike (not Matt) Rattray
*Expert Elite*
jtylerbc
Message 3 of 4 (134 Views)
Re: View updates
05-04-2012 06:32 AM in reply to: mrattray
And depending on whether you're actually opening (moving) the door or just turning its visibility off to visually remove it, you might also want to look at positional representations.
John Tyler
Inventor 2013
Windows 7 64 Bit
Employee
Message 4 of 4 (122 Views)
Re: View updates
05-04-2012 01:21 PM in reply to: Bobeep
I am sorry that I may not fully understand your workflow here. But, it sounds like you might have created some drawing views from upper level assembly when all you need is the views of the subassembly. Would creating subassembly view help here? Could you attach an image here or an assembly showing the problem you have?
Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
Autodesk, Inc.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
