When I edit a part directly in an assembly, clicking on 'edit sketch' (frequently) changes the view from the one I had set while looking at the assembly. Is ther any way to turn this OFF?
Solved by JDMather. Go to Solution.
Tools>Application Options>Sketch tab
uncheck
Look at sketch plane on sketch creation.
(although if you are doing Edit Sketch....)
