Hello there,
given I do a foreshortened view. Is there a way to fit the shortenings parameters to a view in a different window with a different reference file?
If not it would be a little awkward to achieve exactly the same result with a different file. As replacing references does´nt work with single view
representation I´m stuck with manual- non constrained alignment of view details... which can´t be right I guess.
Would be really helpful if there was a way to do it "right" without the need to switch to AutoCAD.
Kind regards
Daniel
I suggest you post a picture of what you're trying to do... might jog some ideas.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
yes I'm a little unclear of what the OP is asking about too
Daniel,
Sounds like you are talking about a broken view and you want to change the model reference to that without changing the mother view?
If that is the case I do not know of a way to do that.
If not, I agree with the others in that posting images would help.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hello there,
yes a broken view... I want to dimension the "break lines".
I will upload a picture on monday!
Thanks !! And sorry for replying late...
I don't think there is any way to dimension the Break lines. Even creating a sketch and trying to project them fails.
Why do you want to do this?
Hello there,
finally a picture to make my explanation work...
It´s a pity, there is no option to dimension the foreshortened view. I tried
to clone the "shortened" view to later change the file path of the reference,
in the copy, but Inventor block´s that option.
Therefore I did not manage. I think I could put all the cranes in one assembly
and use different views for an overlay, but I really don´t think it´s fun to handle
about 250 MB for each crane in one huge IAM file.
Such a pity...
Create your base, view, then shorten it. Then create your secondary views from this base view. They will be the same height and the shorten will be in the same place. You can always drag the view to another sheet in the browser window.
What Blar is said should work for you. I have done it so I know it does work. If this is not what you are talking about please let us know it there was a misunderstanding.
