Inventor General
Message 1 of 4 (884 Views)
Verify if parameter exists - iLogic
884 Views, 3 Replies
11-05-2012 11:42 AM
How can I verify if one parameter exists ?
Im doing a code to add some needed parameters in some drawings, i can create the parameters with the code below, but, if there is any parameter with the same name..it creates another one with _ in front of its name..
I tried to verify with a simple If but didnt work :smileyfrustrated:
This is the code that create those parameters, still with just 2 for tests:
Imports  Inventor.UnitsTypeEnum
 Dim oParams As Parameters
oParams=ThisApplication.ActiveDocument.Parameters
Dim oUserParams As UserParameters
oUserParams=oParams.UserParameters
oUserParams.AddByValue("ref_ID1","PT",kTextUnits)
MultiValue.SetList("ref_ID1","ES","EN","FR", "PT")
oUserParams.AddByValue("ref_ID2","EN",kTextUnits)
MultiValue.SetList("ref_ID2","0 - Sem idioma secundario", "ES","EN","FR", "PT")
Thanks very much, again!
Túlio Barata
IV 2013
Valued Mentor
rhasell
Message 2 of 4 (871 Views)
Re: Verify if parameter exists - iLogic
11-05-2012 03:23 PM in reply to: tuliobarata
Hi
I have manged to get info from the forum and have made-up this piece of code.
I am no Guru, but perhaps you can work with this workflow and customize this for yourself?
' Create Custom Paramteres if not done.
Dim oPartDoc as PartDocument = ThisDoc.Document
Dim userParams As UserParameters = oPartDoc.ComponentDefinition.Parameters.UserParameters
Try
  BOLT_Params = oPartDoc.ComponentDefinition.Parameters("BOLT_SIZE")
Catch
    Dim newParam As UserParameter = userParams.AddByExpression("BOLT_SIZE", 0, "mm")
End Try
Try
  BOLT_OFFSET_param = oPartDoc.ComponentDefinition.Parameters("BOLT_OFF")
Catch
    Dim newParam As UserParameter = userParams.AddByExpression("BOLT_OFF", 0, "mm")
End Try
Try
  BOLT_OFFSET_param = oPartDoc.ComponentDefinition.Parameters("BOLT_H")
Catch
    Dim newParam As UserParameter = userParams.AddByExpression("BOLT_H", 0, "mm")
End Try
Parameter("BOLT_OFF")="BOLT_SIZE*1.5"
Parameter("BOLT_H")="BOLT_SIZE+4"
Reg
Autodesk Product Design Suite Premium 2014 SP1-Update 2 Build 222
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please accept as a solution if it fixes your problem.
Employee
Message 3 of 4 (861 Views)
11-05-2012 09:15 PM in reply to: tuliobarata
Please see the function to check whether the parameter exists -
Function ParaExist(sName) As Boolean
Dim blTag As Boolean
blTag = False
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
oCompDef = oDoc.ComponentDefinition
For i = 1 To oCompDef.Parameters.Count
If oCompDef.Parameters(i).Name = sName Then
blTag = True
Exit For
End If
Next
ParaExist = blTag
End Function
River Cai
Inventor Quality Assurance Team
Message 4 of 4 (842 Views)
11-06-2012 03:06 AM in reply to: Yijiang.Cai
Good morning all !
Thanks Cai and rhasel!!
The code is working perfectly now! Actually, i didnt understand very well the Cai's code, it didnt work. But the rhasel's, i just changed some details and now is working as i need!
This is the final code:
Dim oPartDoc as DrawingDocument = ThisDoc.Document Dim userParams As UserParameters = oPartDoc.Parameters.UserParameters Try parametro = oPartDoc.Parameters("param1") Catch Dim newParam As UserParameter = userParams.AddByValue("param1","a",kTextUnits) End Try Try parametro = oPartDoc.Parameters("param2") Catch Dim newParam As UserParameter = userParams.AddByValue("param2","a",kTextUnits) End Try Try parametro = oPartDoc.Parameters("param3") Catch Dim newParam As UserParameter = userParams.AddByValue("param3","a",kTextUnits) End Try
Actually i dont know why, but i had to remove the ComponentDefinition from the code, and just change the oPartDoc line.
Thanks to both!
Túlio Barata
IV 2013
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
