Inventor 2013 had a option where you could download parts or assemblies from different vendors
from inside Inventor. I do not find it in Inventor 2014. I think it was on the Get Started \ Samples Tab.
Would anyone know if it is still included in Inventor 2014 and where it is located.
Gaitano
Solved by JDMather. Go to Solution.
Do you have an Autodesk360 tab on your Ribbon?
also check GrabCAD
JD;
Yes thats it, I thought Inventor did away with it. I never use the 360 tab.
Appreciate it much!
Gaitano
