Inventor Forum
Vector Map Disfigured
18 REPLIES 18
Message 1 of 19
gw09sherryrobert
960 Views, 18 Replies
I imported a Vector Map from Adobe Illistrator, to Inventor. However, when I go to extrude the logo into the model, dispite looking fine in the drawing, claim's there are inter-secting loops and shows it as disfigured.
http://imgur.com/a/kb8I5
18 REPLIES 18
Message 2 of 19
JDMather
in reply to: gw09sherryrobert
Attach original image file here.
and the Inventor file
Find the red End of Part marker in the browser.
(End of Folded on sheet metal parts EOF)
Drag the red EOP to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
Right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Did you turn off autoconstrain on import?
Message 3 of 19
gw09sherryrobert
in reply to: JDMather
I'm unable to move the EOP marker O_o
Do you want the .dwg I imported as well or just the image file?
Message 4 of 19
Ah. I was in scetch mode. Rookie error sorry.
Message 5 of 19
gw09sherryrobert
Here are the files you requested.
I added the logo's .dwg incase you wanted it as well.
Message 6 of 19
And you'll need the link aswell I believe.
Message 7 of 19
JDMather
The original imput was not really appropriate quality.
Even the "circles" are splines.
I will try to see what I can do with fixing it up (in AutoCAD) on Monday.  (I don't have my notes in front of me.)
I will be trying to reduce to arc segments and lines.
Frankly, I think your best bet is to start from srcatch rather than use this art.
But even with that art - I am sure better results can be obtained without too much work.
Message 8 of 19
gw09sherryrobert
Yeah. I know. But it was the best I could get.
I thought autocad might be the answer but I'm not even that proficent in inventor.
Message 9 of 19
JDMather
With just a few minutes of effort I was able to dramatically improve the sketch.
I will see on Monday how much more improvement can be made.
Message 10 of 19
gw09sherryrobert
Wow. I really need to learn how to work with vectors.
Message 11 of 19
rdyson
Five minute in Rhino. The dwg came in just as in the attached, no manuipulation. (EOP rolled up)
PDSU 2016
Message 12 of 19
gw09sherryrobert
in reply to: rdyson
I should point out that I'm using 2010, so I can't open that.
Message 13 of 19
JDMather
Students can download the latest version of Inventor here http://www.autodesk.com/edcommunity
Message 14 of 19
gw09sherryrobert
Yeah. But my Academy use's 2010, so I need to use 2010.
Message 15 of 19
rdyson
Does 2010 read Rhino 3dm's?
PDSU 2016
Message 16 of 19
gw09sherryrobert
in reply to: rdyson
Nope.
Apparently not.
Could you guys tell me what I'm doing wrong?
I'm making gifts for my friends and the is literally happening to _everything_
Message 17 of 19
rdyson
If you're a student, you can buy a copy of Rhino for small money.
PDSU 2016
Message 18 of 19
gw09sherryrobert
in reply to: rdyson
95 Euro's is hardly cheap O_o
Also, any update on the vector map stuff JDMather?
Message 19 of 19
rdyson
90 Euro's, about a month's worth of Starbucks!
PDSU 2016
