I have noticed today that my Vault ribbon is not working. I can log in / log out of the Vault and navigate to the Vault explorer. Also in the browser I only have access to model and favorites. It acts like the Vault project is not active.
The project file is active and mapped properly and I can check files in and out via the Vault explorer. I have also installed updates dl19384851 and update 1 for Inventor.
I am running Windows XP Pro x86 & Vault Professional.
Any suggestions?
Solved by jason.rogers. Go to Solution.
Hi jason.rogers,
Most often this is due to the fact that your Vault project file is not active. Close all Inventor files then go to the Get Started tab > Projects button and ensure that your Vault project is the active one.
I hope this helps.
Curtis
Thanks for the reply, but the Vault project is active. I have even tried different vault projects with the same result.
Hi jason.rogers,
I now see where you said you'd checked that beforehand.
Have you gone to the Tools tab > Add-Ins button > and checked for the EDM addin? Note that you'll likely need to right-click on the Addins list and choose Show Hidden Members to make sure it's there or not there.
I hope this helps.
Curtis
It seems to have fixed itself. I shut down the computer last night and when I restarted it this morning everything was working fine.
Very frustrating. I restarted several times yesterday, recreated Vault projects and nothing.
Who knows,but its working now.
