Inventor Forum
Vaccum Simulation
2 REPLIES 2
F.Goncalves
301 Views, 2 Replies
Vaccum Simulation
Hi!
I need help doing one simulation study.
I want to simulate what happens to, for example, an coke can when its subject to full vaccum inside.
So, what i normally would do its do apply yo the inner faces of the solid one pressure to the inside of +/- 0.1MPa (equivalent to almost full vaccu force [1kg/cm2]).
Until tis point its easy, my problem is what face do I select as fixed. Nothing is fixed when full vaccum is applied, the can is just standing on the table and it can compress in all directions. But if i don't select any face as fixed Inventor does no alow me to simulate.
any help on this?
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
F.Goncalves
2 REPLIES 2
JDMather
in reply to: F.Goncalves
Check this
blair
Or just select the top face of the opening.
Delta Tau Chi ΔΤΧ
