"Andreas_B" <Hello
href="mailto:a.buchhorn@siteco.de">a.buchhorn@siteco.de> wrote in
message
href="news:f13b0c9.-1@WebX.maYIadrTaRb">news:f13b0c9.-1@WebX.maYIadrTaRb...
all
is there anybody using viz4 and inventor ?
there is a special
plugin to import inventor-files in viz4. can install and start the
import-function but it aborts with the following message:
C:\programme\Autodesk VIZ 4
Unable to load Autodesk Inventor libraries!
Import of selected Inventor file will be aborted.
we use VIZ4,2 SP 2 and Inventor 2 SP1 Build 106c (german) also tried it
with inventor 5 and got the same error.
if you don't have problems, please tell me the versions you use.
Any tips ????
(i think it's a bug , Autodesk are you listening)
Andreas
"Andreas_B" <Hello
message
all
there is a special
Any tips ????
Andreas
"Patrick de Stobbeleir" <
href="mailto:pdsa@hotmail.com">pdsa@hotmail.com> wrote in message
href="news:E2B40B7A9C02270E833F70076F76117E@in.WebX.maYIadrTaRb">news:E2B40B7A9C02270E833F70076F7......
Download the updated plugin from
href="http://support.autodesk.com/enu/Homepage.asp">
color=#000000>http://support.autodesk.com/... make
a search for id DL403701
"Andreas_B" <Hello
message
all
there is a special
it with inventor 5 and got the same error.
Any tips ????
Andreas
"Andrew Pawelski" <
href="mailto:andrew.pawelski@valiantREMOVEmachineTHIS.com">andrew.pawelski@valiantREMOVEmachineTH...>
wrote in message
href="news:02633F0ED2590EF442C7D559BBF5216B@in.WebX.maYIadrTaRb">news:02633F0ED2590EF442C7D559BBF......
While on the topic... Autodesk: how far away is
an update patch for the part name truncation bug when importing IV into 3ds
max?
Andrew
"Wayne Catalfano" <
href="mailto:wayne.catalfano@autodesk.com">wayne.catalfano@autodesk.com>
wrote in message
href="news:D48C9537806C6BB4855F2B45E94100F6@in.WebX.maYIadrTaRb">news:D48C9537806C6BB4855F2B45E94......
I can say that we are working on the issue.
I am not in a position to coment on when updates are planned.
Wayne
"Andrew Pawelski" <
href="mailto:andrew.pawelski@valiantREMOVEmachineTHIS.com">andrew.pawelski@valiantREMOVEmachine...>
wrote in message
href="news:02633F0ED2590EF442C7D559BBF5216B@in.WebX.maYIadrTaRb">news:02633F0ED2590EF442C7D559B......
max?
size=2>Andrew
"Andreas_B" <Hi
message
href="news:f13b0c9.6@WebX.maYIadrTaRb">news:f13b0c9.6@WebX.maYIadrTaRb...
Wayne,Patrick, Andrew
You are right, of course we use Inventor 6 SP1.
next question: the update Patrick pointed out should work or
does work
?! is there anybody who really tried it ?
We used this updated plugin and
i'm quite sure i have done a correct installation. If you make mistakes (using
wrong files etc.) you will not be able to start the import-function.
In my
case viz4 is loading the plugin without errors and i can start the
import-function, choose a inventor-file, get the first dialogbox, click ok and
then i get the error message (see above)
My dealer in germany get's the
same error !!! and is in contact with autodesk.
Perhaps it's a error with
the german version of inventor ?
just wanted to know, what's happening in the wide world. I'm waiting
for an answer for weeks !!!
so again my question : should it work or does it work?
also
with english version VIZ4,2 SP2
and
german version inventor 6 SP1
I really want to work!
Please help me again
Andreas
