Inventor Forum
VBA to print "All Sheets"
4 REPLIES 4
karthur1
1771 Views, 4 Replies
I am trying to get the PDF macro to be hard coded to print all the sheets in an idw.  I added this line (guessed at code basically), but it didnt work.  Where do I find what the correct syntax should be for this code?
4 REPLIES 4
karthur1
in reply to: karthur1
Nevermind... just figured it out.
oPrintMgr.PrintRange=kPrintAllSheets
mmoucka
Good morning.
Thank You for help.
Please, why are the parameters hidden (not visible in list of members) ? Are there more important things ?
Thank You.
MechMachineMan
in reply to: mmoucka
You just need to know where to look.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-C11168B3-80C0-4A03-9525-77381C503B96
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
mmoucka
in reply to: MechMachineMan
Many thanks ! Smiley Happy
