Inventor General
Message 1 of 2 (218 Views)
VBA or VB for sculpting overlapping objects in an Assembly??
218 Views, 1 Replies
10-19-2012 08:55 AM
Hi
I have an assembly with various parts in it.  I am trying to write a routine that will
1) systematically traverse the assembly and find parts that overlap,
2) where they overlap perform a sculpt operation on the parts
Whilst i can do this manually by edit>copy object>sculpt>select surface ...  i don't know how to mimic this programmatically.
 So far i have coded to do it in a very hamfisted way by making a derived part file from the overlapping parts, opening the derived part file and performing the sculpt, replacing the original part in the assembly with its new derived-sculpted part and then continuing to traverse the assembly tree..  - it is super slow and uses lots of file operations.
Does anyone have any examples of a slick way to do this??
Thanks in advance
regards
Dan
Curtis_Waguespack
Message 2 of 2 (212 Views)
Re: VBA or VB for sculpting overlapping objects in an Assembly??
10-19-2012 09:02 AM in reply to: mitcham_boy
Hi mitcham_boy,
You might have better luck searching and asking questions of this type on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
