I have the student version of Inventor 2014 installed on my computer. My O/S is Windows 7 Ultimate 64 bit. I have installed and reinstalled Microsoft Visual Basics three times. But, I am still getting the error "VBA failed to initialize properly". Can someone tell me what is wrong? The program was working fine for about a week with no errors reported. Now, every time I try to start a tutorial I get this error. Thanks for any assistance.
Thank you for reporting the issue.
Would you mind providing a screen shot of the error message and your application options > [File] tab setting?
We're curious to know what your "Default VBA project" is.
Best,
-Sami Harada
Inventor Framework QA
The problem is fixed. I went to my control panel and reinstalled the files. I don't know what caused the problem, but that fixed it.
Even after a reinstall, I still got this error. This link has the fix that worked for me...
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21910314&linkID=9242018
This worked for me as well for Inventor 2014.
Standalone:
Close Inventor session and manually install VBA7 from Inventor source media:
64-bit
Install VBA7 from "3rdParty\x64\VBA\Vba7.MSI" .
32-bit
Install VBA7 from "3rdParty\x86\VBA\Vba7.MSI" .
Deployment:
64-bit
Deploy VBA7 installer to the client from "3rdParty\x64\VBA\Vba7.MSI".
32-bit
Deploy VBA7 installer to the client from "3rdParty\x86\VBA\Vba7.MSI".
