Inventor General
Active Member
alanrichardson
Message 1 of 6 (445 Views)
Accepted Solution
Using Unfold
445 Views, 5 Replies
07-05-2010 11:46 PM
Is it possible to use the unfold option (sheetmetal/modify tab) to show vaious stages in folding a component in a drawing. (as you can with pos reps)?
I am currently using three ipt files to show the various stages of a part in a drawing, there must be a better way?
Cheers
Alan Richardson
Inventor Product Design Suite 2012 Service Pack 1
Dell Precision T1500
Intel(R) Core(TM) i7 CPU 860@2.80 Ghz
NVIDIA Quadro FX580
4 GB RAM
Windows 7 Pro x64
Space Navigator (driver 6.13.1)
Valued Mentor
delineryan
Message 2 of 6 (429 Views)
Re: Using Unfold
07-06-2010 05:42 AM in reply to: alanrichardson
You could use unfold with iParts, or if you used the fold command you can just suppress those in and iPart too.
Post your file for a definite answer.
Cheers,
Ryan
Ryan
Inventor Version:
Build: 535, Release: 2011 SSR - Date: Fri 08/20/2010
64-Bit Edition - 8192.00 GB
Dell Precision T3500
Intel(R) Xeon(R) CPU W3540 @ 2.93GHz (8 CPUs), ~2.9GHz
6.00 GB RAM
Windows Vista™ Ultimate (6.0, Build 6002) Service Pack 2
NVIDIA Quadro FX 1800 8.17.0012.5849
**Master
BMiller63
Message 3 of 6 (407 Views)
Re: Using Unfold
07-06-2010 11:36 AM in reply to: alanrichardson
You can use an iPart to do this, create the fold or unfold feature and suppress the features in the ipart.
see if this helps (it should be an animated GIF file, open in web browser to play):
http://forums.autodesk.com/autodesk/attachments/autodesk/78/230523/1/part2.gif
Active Member
alanrichardson
Message 4 of 6 (379 Views)
Re: Using Unfold
07-07-2010 02:50 AM in reply to: delineryan
Hi Ryan
Thanks for the info . . . File attached (I Hope)
Regards
NVIDIA Quadro FX580
4 GB RAM
Windows 7 Pro x64
Valued Mentor
delineryan
Message 5 of 6 (364 Views)
Re: Using Unfold
07-07-2010 05:35 AM in reply to: alanrichardson
I got your file and it will work good using an ipart, just suppress the unfold or refold where needed.  I can't post the file back because I am running 2011 but I have posted a screenshot of what I think the ipart table will look like.
Cheers,
Ryan
Inventor Version:
6.00 GB RAM
Active Member
alanrichardson
Message 6 of 6 (354 Views)
Re: Using Unfold
07-07-2010 05:53 AM in reply to: delineryan
Thanks Ryan, I'll give that a try . . .
(I am currently using 2010 but 2011 is on site awaiting installation!)
Alan
NVIDIA Quadro FX580
4 GB RAM
Windows 7 Pro x64
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
