I would like to know if it is possible using Ilogic to automatic create drawings for parts. I know that it's not always gonna be perfect and I'll have to do some adjustments, but to create the main dimensions, views, etc. Is there a program that I can create using Ilogic that will be able to accomplish that in Inventor 2014?
Thank you very much.
Solved by mrattray. Go to Solution.
Hi due303,
There are 13 pages of discussion on this topic at this link, so you migth be able to find something helpful there:
I hope this helps.
Curtis
Yes, but it's not easy and "your results may vary". Here's an in dpeth discussion on the topic:
http://forums.autodesk.com/t5/Inventor-Customization/iLogic-Coding-to-Create-Automated-Drawing/m-p/3...
