Inventor General
New Member
Message 1 of 6 (489 Views)
Using Cotter Pin in assembly
489 Views, 5 Replies
01-28-2010 06:59 PM
I have created a part which has 3 holes. I would want to secure these holes with cotter pins. How do i do it? I tried using the iMate function, but i couldnt get the imates of the cotter pin to match iMate of the holes. I tried doing a custom iMate for the holes but i couldnt get it to work. I tried the component generator too, but it only adds the iMate to one of the holes.
would appreciate some help.
**Master
Message 2 of 6 (489 Views)
Re: Using Cotter Pin in assembly
01-29-2010 06:14 AM in reply to: jchua83
Rather than use the iMates, just manually contrain it with mates and/or inserts. Also, you might post some example files and someone will be glad to show you exactly how to achieve this.
New Member
Message 3 of 6 (489 Views)
01-29-2010 06:28 AM in reply to: jchua83
I attached a sample of the part im building. I need to put cotter pins in the left and right hole.
Hope someone can help me
Distinguished Contributor
Message 4 of 6 (489 Views)
01-29-2010 06:54 AM in reply to: jchua83
I'm looking at you're part, are you sure you mean cotter pins? and not retainer pins? Or cotter pins into the retainer pins that go into those holes? It looks to me like something is missing.
msk
Distinguished Mentor
Message 5 of 6 (489 Views)
01-29-2010 07:26 AM in reply to: jchua83
Not sure exactly what you want either. Attached is a zip file with one possibility.
Post a screen shot of the assy you are working on and that will help.
Hope this helps, Paul Edited by: pauldoubet on Jan 29, 2010 9:26 AM
Message 6 of 6 (489 Views)
01-29-2010 08:35 AM in reply to: jchua83
FIRST attachment only had one part a plate with holes.
msk
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
