Inventor General
Active Member
ENGSIN-DAShipman
Message 1 of 8 (283 Views)
Using Autodesk Inventor with Non-Admin User rights
283 Views, 7 Replies
09-09-2013 05:14 AM
Due to our new company policies, we cannot have any users on our computers be local administrators to the computer itself.  We need to know of what settings we need to place into effect on these computers we have running the current software we hold.
What we will need to know is;
What section/s of the Registry the software needs Read/Write access to?
What Directory/ies the software needs Read/Write access to?
mcgyvr
Message 2 of 8 (279 Views)
Re: Using Autodesk Inventor with Non-Admin User rights
09-09-2013 05:29 AM in reply to: ENGSIN-DAShipman
http://downloads.visucate.com/support/Deploying_Inventor_in_Schools.pdf
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11768501&linkID=9242018
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18138720&linkID=9242018
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Cadmanto
Message 3 of 8 (269 Views)
09-09-2013 05:50 AM in reply to: ENGSIN-DAShipman
What version of Inventor are you running?
Also, are you using Vault?  If so there are permissions with in there that need to be considered as well.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Active Member
ENGSIN-DAShipman
Message 4 of 8 (255 Views)
09-09-2013 06:59 AM in reply to: Cadmanto
Vault is installed locally on each machine but is not used.
The version of Inventor we are using is 2012.
Cadmanto
Message 5 of 8 (252 Views)
09-09-2013 07:05 AM in reply to: ENGSIN-DAShipman
Any particular reason why you are not using vault?  What version of vault?  Pro, collaboration, workgroup?
If I were you I would look into using vault and setting up the permissions there instead of on a network.  I believe you would have better and more secure permissions within the vault then out side.  Plus I believe they are easier to setup as well.
Best Regards,
Scott McFadden
Active Member
ENGSIN-DAShipman
Message 6 of 8 (244 Views)
09-09-2013 07:22 AM in reply to: Cadmanto
We don't require the usage of vault for the three users that use Inventor.They save everything they need on the Server that gets backed up nightly.  The filesd made are later converted into their final product for others in their department.
The reasoning as for why we are not, is that it was up to the department heads to take care of getting it setup for their group, but use the servers for their secure folder storage and file management instead of the Vault software.
Active Member
ENGSIN-DAShipman
Message 7 of 8 (243 Views)
09-09-2013 07:24 AM in reply to: mcgyvr
Those look pretty much like I was looking for though they don't have much on the Registry side except the activation portion which would not be much of a problem.
Thanks for the quick response in this.
mcgyvr
Message 8 of 8 (226 Views)
09-09-2013 08:39 AM in reply to: ENGSIN-DAShipman
No problem.. I google well :smileywink:
Windows 7 64 bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
