Solved by mcgyvr. Go to Solution.
Yes.. the problem is you don't know how to attach files..
First.. I would start with that "Choose File" button right under where you type out the body of your question on this forum..
Let me know if you need more assistance 😉 🙂
@Anonymous wrote:
Congratulation:) you found first problem. I am waiting same performance to solve second problem from you:) Other Problem is that (at attached file) that is i hope it is attached
Fail 2...
