I design cushions for airplane seats and am trying to display a leather cover on the cushions with pull lines for piping detailing. etc. I am also wondering if a leather material style is availble for DL online.
Solved by JDMather. Go to Solution.
http://forums.autodesk.com/autodesk/attachments/autodesk/78/405670/1/Seat.jpg
cloth rather than leather - but there are webistes (cbliss is one) that have material images.
I see you did a double post of the same question
http://forums.autodesk.com/t5/Autodesk-Inventor/Modelling-Leather-Coverings/td-p/3573072/page/2
that is generally frowned upon as is causes confusion when someone else searches for solutions.
The CADWhisperer YouTube Channel
Yes i didnt mean to. I was hoping to be able to contact you to find out how you did that seat I saw as an example under the leather coverings post by a different person. How did you acheive what appears to be the piping?
@cbell1007 wrote:How did you acheive what appears to be the piping?
Sweep
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%207.pdf
Note that the image of the seat I posted is very old now and this tutorial is out-of-date.
It is no longer necessary to extrude the surfaces to get the 3D path. You can now project one 2D sketch onto another directly when creating the 3D sketch.
