Inventor General
Product Support
bobvdd
Message 11 of 11 (84 Views)
Re: Updating the appearance of a derived part
06-21-2012 12:16 PM in reply to: mrattray
I can not directly reproduce what you are seeing.
The other element that certainly will play here is what you have stored in your Inventormateriallibrary.adsklib file.
I did see a ton of duplicate appearances used by various materials that you have defined in your template file.
The duplicates (styles with same name and  a number between round brackets) is a known problem that has not been solved by Update1.
What I would do in your case is to save the custom styles that you are happy with and that you want to keep, to the Inventor adsklib library and remove the cached styles in your template file by purging (Manage > Purge). You won't be able to remove these duplicate styles with delete.
Bob
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
