I am looking to add Acme screws to my project file - I am using the thread sheet from this thread. My question is, can I add these threads to my project as I need to be able to edit this project on multiple computers (the project is synced with git)?
Istvan.
Solved by SBix26. Go to Solution.
Thread.xls is part of Design Data, so unless you're defining a separate Design Data folder for your project, you'll be modifying the default one defined by Application Options. Shouldn't be a problem, though-- it just means that Acme threads will be available to all projects.
