Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Update line weights
3 REPLIES 3
308 Views, 3 Replies
Update line weights
I just had Inventor 2010 reinstalled on a new workstaion with Windows 7.
On any new drawings my line weights are fine.
On any drawings created before the new install, the line weights are all the wrong thicknesses now when I open them on my machine. They used to be fine and to our company standard.
How do I get it to where my line weights are correct on all idw drawings.
3 REPLIES 3
blair
Odd, why the old drawing that "were fine" have now become "wrong". Do the drawings Plot/Print fine, or is it just a display issue?
I might try the "Drawing Resource Transfer Wizard". If any of the Borders and Title Blocks have changed as well.
Delta Tau Chi Ī”Ī¤Ī§
in reply to: blair
It is a display issue also.
It doesn't seam to make sense but the layer line weight settings are all different on drawings done before the reinstall.
The templates have not changed.
I used the file transfer wizard and that worked fine if I was only having the problem with 1 drawing, but it is several thousand drawings.
I do not want to have to do this for every drawing.
Cadmanto
What lines weights are exactly not right?  Are you talking about title block line weights, object line weights, centerline weights, text or all of the above?
Is anyone else in your department experiencing this?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
