Inventor General
Valued Contributor
nickv02
Message 1 of 4 (157 Views)
Update Quanities in Parts List based on Parameter in Assembly?
157 Views, 3 Replies
04-12-2012 06:34 AM
Inventor 2012.
Attached is a screenshot of my .idw file with a Parts List based off a .iam Assembly of a sheet metal door.  My question is how would I input the total quantity of doors in the .iam in order to update the Parts List quantity column?  I have a lot of user inputs in the .iam file set up to change width, height, etc that are based off of Parameters in the .iam, but I don't know how the user can enter assembly quantities in order to get the Parts List to update the Quantity column correctly?
I have attempted using custom iProperties but can't figure out any kind of formula to get it to display based off a user input Parameter.
Any thoughts?
Thanks in advance,
Nick
*Expert Elite*
jtylerbc
Message 2 of 4 (152 Views)
Re: Update Quantities in Parts List based on Parameter in Assembly?
04-12-2012 06:54 AM in reply to: nickv02
Not a direct answer to your question, but possibly another way to go about getting what you want:
What about putting your door assembly into a "Shear List Assembly", and doing a rectangular pattern of it?  If you do a one row or one column pattern, then the "count" parameter for the pattern becomes a multiplier for the number of doors.
You then place a "Parts Only" parts list from the Shear List Assembly, so it will show the parts of the door instead of just listing the 5 doors.  All you have to do to update to a different quantity of doors is change that parameter for the pattern.
John Tyler
Inventor 2013
Windows 7 64 Bit
Valued Contributor
nickv02
Message 3 of 4 (149 Views)
04-12-2012 07:14 AM in reply to: jtylerbc
Editing my post:
I was using the wrong rectangular pattern tool.  Your idea worked, and I think I can make it work for my parts list.
Thanks so much !!!!
*Expert Elite*
jtylerbc
Message 4 of 4 (141 Views)
04-12-2012 07:46 AM in reply to: nickv02
Hah!  Wrote my post explaining what you were doing wrong as you were posting that you'd figured it out yourself.
Glad it worked for you - seems like a much easier way than trying to have it do odd things with the quantities in your door assembly.  This way your quantities in the door assembly (and any related drawings) are correct for one unit, but you can get a list quickly of what you need for any quantity.
John Tyler
Inventor 2013
Windows 7 64 Bit
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
