Inventor Forum
Update Drawing Template in Inventor
7 REPLIES 7
Message 1 of 8
samstreet101
7408 Views, 7 Replies
I've been trying to find a way to do this and have come up with nothing but any suggestions would be welcome.
Here's the problem:
I have a drawing template with a custom title block that I use for manufacture drawings. However, some of my older projects used a different title block from an older template. I want to change these older drawings over so they use the newer title block. Is there a way to simply update the template those drawings use to the newer one? Such as a 'change template' option in the management options? Can't see anything myself but any help would be appreciated.
7 REPLIES 7
Message 2 of 8
robbeckley
in reply to: samstreet101
Try Auto Drawing Resources 32/64Bit 'googled', I have used this in the past.
Rob B.
Win7 64 Pro - Asus P8P67 PRO - i5-2500k CPU O/C@4.5Ghz- OCZ Vertex 2 SSD - 8GB Ram - GTX550 Ti - SpaceExplorer.
Message 3 of 8
samstreet101
in reply to: robbeckley
That's pretty much what I was after. Many thanks for that.
Message 4 of 8
robbeckley
Your welcomeSmiley Happy, I have had the particular joy of a customer wanting their own logo placed on drawings they 'paid for' another one of those fun non chargeable administrative tasks.
Rob B.
Message 5 of 8
SBix26
The Drawing Resource Transfer Wizard installed with Inventor will do this for you (Start menu > Inventor 20xx > Tools).
Message 6 of 8
john.laidler
Easiest way, copy/paste title block from the new template to the older files.
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 7 of 8
samstreet101
in reply to: SBix26
Can't see that option. Sure it's under the tools ribbon?
Message 8 of 8
robbeckley
No not within Inventor, use the start menu.
 Windows Start Menu, Program files, Autodesk, Autodesk Inventor 2013, Tools
Rob B.
