Inventor General
Message 1 of 8 (1,659 Views)
Update Drawing Template in Inventor
1659 Views, 7 Replies
12-10-2012 04:26 AM
I've been trying to find a way to do this and have come up with nothing but any suggestions would be welcome.
Here's the problem:
I have a drawing template with a custom title block that I use for manufacture drawings. However, some of my older projects used a different title block from an older template. I want to change these older drawings over so they use the newer title block. Is there a way to simply update the template those drawings use to the newer one? Such as a 'change template' option in the management options? Can't see anything myself but any help would be appreciated.
Message 2 of 8 (1,654 Views)
Re: Update Drawing Template in Inventor
12-10-2012 04:38 AM in reply to: samstreet101
Try Auto Drawing Resources 32/64Bit 'googled', I have used this in the past.
Rob B.
Win7 64 Pro - Asus P8P67 PRO - i5-2500k CPU O/C@4.5Ghz- OCZ Vertex 2 SSD - 8GB Ram - GTX550 Ti - SpaceExplorer.
Message 3 of 8 (1,646 Views)
12-10-2012 04:57 AM in reply to: robbeckley
That's pretty much what I was after. Many thanks for that.
Message 4 of 8 (1,644 Views)
12-10-2012 05:03 AM in reply to: samstreet101
Your welcome:smileyhappy:, I have had the particular joy of a customer wanting their own logo placed on drawings they 'paid for' another one of those fun non chargeable administrative tasks.
Rob B.
*Pro
sbixler
Message 5 of 8 (1,637 Views)
12-10-2012 05:23 AM in reply to: samstreet101
The Drawing Resource Transfer Wizard installed with Inventor will do this for you (Start menu > Inventor 20xx > Tools).
Valued Mentor
jclaidler
Message 6 of 8 (1,633 Views)
12-10-2012 05:46 AM in reply to: samstreet101
Easiest way, copy/paste title block from the new template to the older files.
_______________________________________________________________
ITO - Application Management
Factory Design Suite Ultimate 2012
AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
Message 7 of 8 (1,619 Views)
12-10-2012 07:37 AM in reply to: sbixler
Can't see that option. Sure it's under the tools ribbon?
Message 8 of 8 (1,613 Views)
12-10-2012 07:41 AM in reply to: samstreet101
No not within Inventor, use the start menu.
 Windows Start Menu, Program files, Autodesk, Autodesk Inventor 2013, Tools
Rob B.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
