Inventor General
Distinguished Contributor
Message 1 of 5 (175 Views)
Update Copied Properties automatically
175 Views, 4 Replies
02-01-2014 11:08 AM
Does anyone know a way, either with iLogic, VB, or just an option somewhere, that I can perform the "Update Copied Properties" function (found under the "manage" tab in a drawing) automatically on save? I copy properties to my DWG from my assembly but it only copies the first time and won't automatically update if I change something in the assembly iProperties. Thanks!
Valued Mentor
BLHDrafting
Message 2 of 5 (146 Views)
Re: Update Copied Properties automatically
02-02-2014 07:16 PM in reply to: drguitarum2005
Try this iLogic code from Being Inventive.
http://beinginventive.typepad.com/being-inventive/2012/11/update-automatically-drawing-properties-fr...
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
Message 3 of 5 (125 Views)
02-03-2014 06:29 AM in reply to: BLHDrafting
That looks like exactly what I need. Not sure why that was so hard for me to find. Thanks!
Message 4 of 5 (104 Views)
02-03-2014 12:12 PM in reply to: drguitarum2005
Well now I have a weird problem. I added the following code to my iLogic browser and set it to run before save (also set it to after save, still problems):
Dim oControlDef as ControlDefinition
oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("UpdateCopiedModeliPropertiesCmd")
oControlDef.Execute2(True)
And now I save the document, my other rules run, this rule seems to run, but document doesn't appear to actually save. I say this because I go to Vault>Check In and it says I need to save my drawing, so I say yes, my rules run, then nothing happens. I press check in again and it repeats the same process.
As soon as I suppress this new Copy Properties rule, I check in, it asks me to save, I say yes and it checks in no problem.
Any ideas?
Valued Mentor
BLHDrafting
Message 5 of 5 (94 Views)
02-03-2014 01:21 PM in reply to: drguitarum2005
Bugger! Happy to supply the code but that's where my iLogic knowledge ends.
Maybe if you post this on the Inventor Customisation forum you might get a better answer. http://forums.autodesk.com/t5/Inventor-Customization/bd-p/120
Brendan Henderson
Web www.blh.com.au
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
