Inventor General
Member
DLIDHYDRA
Message 1 of 5 (176 Views)
Unwanted detail in drawings.
176 Views, 4 Replies
01-17-2013 03:58 AM
In the idw of my assembly hidden detail is turned off although there is still sub assemblies shown through the main container. Also when there is a section these sub assemblies are show with dotted lines an overlap compionets they are behind.
My questions are
1. Why are they showing through components they are behind.
2. Why are the lines dashed
See attached image
Please help
*Pro
sbixler
Message 2 of 5 (163 Views)
Re: Unwanted detail in drawings.
01-17-2013 04:37 AM in reply to: DLIDHYDRA
Those appear to be hidden lines-- are you sure that those views have hidden lines turned off?  Otherwise, it's possible that those components are set to Reference in the assembly, which means that they will not appear in parts lists, and will, by default, show as phantom in the drawing.
What version of Inventor are you using?
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Member
DLIDHYDRA
Message 3 of 5 (149 Views)
01-17-2013 05:19 AM in reply to: sbixler
Yes they definatley have hidden lines turned off otherwise all the componts would show wouldnt they? As it is only 6 sub assemblies this is happening with.
What do you mean by set to reference in the assembly?
Inventor 2012
*Pro
sbixler
Message 4 of 5 (143 Views)
01-17-2013 05:40 AM in reply to: DLIDHYDRA
In the assembly, right click on the component and choose iProperties.  On the Occurence tab, see if Reference is checked.
Sam B
Member
DLIDHYDRA
Message 5 of 5 (128 Views)
01-17-2013 08:06 AM in reply to: sbixler
Reference was checked now changed it to default now and is perfect
Thanks would have never got that.
David
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
