Inventor Forum
Unwanted detail in drawings.
4 REPLIES 4
359 Views, 4 Replies
In the idw of my assembly hidden detail is turned off although there is still sub assemblies shown through the main container. Also when there is a section these sub assemblies are show with dotted lines an overlap compionets they are behind.
My questions are
1. Why are they showing through components they are behind.
2. Why are the lines dashed
See attached image
Please help
4 REPLIES 4
SBix26
Those appear to be hidden lines-- are you sure that those views have hidden lines turned off?  Otherwise, it's possible that those components are set to Reference in the assembly, which means that they will not appear in parts lists, and will, by default, show as phantom in the drawing.
What version of Inventor are you using?
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
in reply to: SBix26
Yes they definatley have hidden lines turned off otherwise all the componts would show wouldnt they? As it is only 6 sub assemblies this is happening with.
What do you mean by set to reference in the assembly?
Inventor 2012
SBix26
In the assembly, right click on the component and choose iProperties.  On the Occurence tab, see if Reference is checked.
Sam B
in reply to: SBix26
Reference was checked now changed it to default now and is perfect
Thanks would have never got that.
David
