Try opening the file in MDT and Saving it, then do the translation while it is still open.
If that doesn't help post the file to IVCF and I am sure someone here will give it a shot.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"dsapp" wrote in message news:f17ceb5.-1@WebX.maYIadrTaRb...
> I need help! I can not translate a dwg drawing into inventor 7. I keep getting and error
message that says "Unsupported Operation, you can not edit autocad mechanical drawings in
mechanical desktop" and then the translation switches to a idw file with a 2d view of some
sort. It does this with any file that I use. Yes, these are mechanical desktop files and
not autocad mechanical files. Has anyone had this same problem or have any ideas. I've
tried all of the re-install options. Help!
