Inventor General
Message 1 of 7 (2,075 Views)
Accepted Solution
Unresolved Link to a Deleted Part
2075 Views, 6 Replies
05-31-2011 06:00 AM
I was recently updating an assembly which contained a part that had been subsequently deleted from my folders. I skipped it while opening the assembly, then deleted the part in the Model Tree (and replaced it with a different component). So, to summarize, the assembly no longer has the part in the Tree, and the part does not exist anymore on my system. These parts and assemblies have not been Vaulted, so that should not be an issue either.
My problem is that every time I open the assembly, it wants me to resolve this deleted part, and I have to skip it every time just to proceed. Once the file is loaded, I get no other issues, no "red cross" items, just a question mark next to the file name at the top of the Tree indicating that the file needs to be resolved.
The old part is gone; I tried recreating it using the same file name, and using the same third-party SAT file from which it was originally generated, but Inventor detects that it's not the original part and won't accept it.
Can anyone shed some light on how to get past this "part resolution" issue?
CrAzY-MiKe
Autodesk Product Design Suite Premium 2013
Inventor 2013 64-bit Edition
Win7-64, 8-core Intel® Xeon® CPU W3550 @ 3.07GHz
NVIDIA GeForce GTX 560 Ti
454 GB HD, Intel® ICH10R SATA AHCI Controller
SpaceNavigator, 3.14.2 / 6.14.0 / 3.18
*Expert Elite*
jtylerbc
Message 2 of 7 (2,063 Views)
Re: Unresolved Link to a Deleted Part
05-31-2011 06:25 AM in reply to: CrAzY-MiKe
I know you said this was originally an imported SAT model so this is unlikely, but is it possible that you have a parameter linked to the part?  That could cause the assembly to still be looking for it even though the part has been removed from the assembly.
John Tyler
Inventor 2013
Windows 7 64 Bit
Message 3 of 7 (2,045 Views)
05-31-2011 08:38 AM in reply to: jtylerbc
I checked, and there is no link in the Parameter table to that old part, or any other part for that matter. All the parameters in the table are consumed by constraints in the assembly. When you delete a part, any constraints associated with it also disappear, so I'm pretty sure there aren't some abandoned contraints floating around in the background.
Thanks for the suggestion, though. I'm glad someone else is mulling this over.
*Expert Elite*
jtylerbc
Message 4 of 7 (2,033 Views)
05-31-2011 08:54 AM in reply to: CrAzY-MiKe
Didn't think that would be the case, but I had a similar situation once that turned out to be due to parameter linking, so I thought I'd throw it out there.
Hopefully someone else will come along with a better idea.  In the meantime, a couple of other suggestions:
1) Make sure there aren't any additional copies of the part buried somewhere in the component patterns.
2) Just noticed this is an iAssembly - check your iAssembly table to make sure there aren't any leftover references to the part there (Suppress/Include states, etc).
John Tyler
Inventor 2013
Windows 7 64 Bit
Message 5 of 7 (2,031 Views)
05-31-2011 09:07 AM in reply to: jtylerbc
Thanks again, I really appreciate your input. I will check for possible buried copies of it.
I also deleted the iAssembly table, since I had only just begun working on it anyway. No change, so that's probably not involved either. Worst case, I'll just rebuild from scratch.
Message 6 of 7 (2,003 Views)
05-31-2011 01:49 PM in reply to: CrAzY-MiKe
FINALLY WORKED IT OUT!
The offending (and no longer extant) part had been replaced by a similar one in the assembly. I had deleted the unresolved entry in the model tree and then placed a current part in the assembly.
On a hunch (or desperate guess) I deleted that replacement part from the assembly, saved my work, closed and re-opened the file.
When Inventor prompted me to resolve the missing file once again, I browsed to the similar one and Inventor accepted the substitution. I was then able to re-place the new part, constrain it and move on.
So apparently it wasn't letting me substitute a part that was already in the assembly. I had to delete the part, then do the sub, then place the part again. Go figure!
akosi
Message 7 of 7 (1,721 Views)
03-20-2012 06:07 AM in reply to: CrAzY-MiKe
hi,
i have the same problem, but in this case , somebody did the assembly so therefore i dont know what was replaced.
the unresolved file is not in the tree nor in the vault.
how to resolved this.
help!
inventor 2011
vault 2012
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
