I'm guessing that it is the Re-Computed Updates setting that is causing the problem, again
Go to the main menu, Tools --> App Ops --> Save(tab) and check/tick the box for Prompt to Save for re-computable updates.
Open the relevant IAM, rebuild and save.
With the IAM still open, open the IDW.
Go to File --> Save All --> Close All.
Now use DA.
HTH
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be
as mad as what passes for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
http://support.microsoft.com/default.aspx/kb/555375
"gcross (IV 2008 Sp2)" wrote in message news:5950332@discussion.autodesk.com...
I get an unresolved file ref error message when I open an IDW file in Design
Assistant but I do not get the error when I open the
files referenced in the path. Opening the IDW shows no ref issues at all &
the "missing" file is in the referenced IDW/IAM files.
The missing file happens to be in a subfolder under my library folder & I
checked that it's there & file name is good, etc.
Why am I getting this error in DA?
Gary
