Inventor General
Valued Contributor
Deadhorse
Message 1 of 6 (153 Views)
Unolding a fold?
153 Views, 5 Replies
01-29-2010 11:36 AM
All I'm doing is scetching a rectangle, creating a face, scetching a line and creating a fold. Why won't it unfold?
V11
*Expert Elite*
JDMather
Message 2 of 6 (153 Views)
Re: Unolding a fold?
01-29-2010 11:46 AM in reply to: Deadhorse
Select a face first.
You are doing too much work though. A countoured flange would be much easier to get the same results.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Mentor
delineryan
Message 3 of 6 (153 Views)
01-29-2010 11:50 AM in reply to: Deadhorse
You could just sketch the open profile, then do a contour flange, I'm sure that would work in v11.
Alternatively,
To fix your model (this worked for me in 2010) follow these steps
1. Delete the flat pattern
2. Move the "End of Folded" marker to just below "Fold 1"
3. Highlight the large flat surface
4. Click flat pattern (it should flatten)
5. Click back to the folded part
6. Move the "End of Folded" marker to just below "Fold 2"
7. Then click flat pattern again
That is what worked for me, I know they have overhauled the sheet metal module since v11 so it may not work for you.
Ryan
Ryan
Inventor Version:
Build: 535, Release: 2011 SSR - Date: Fri 08/20/2010
64-Bit Edition - 8192.00 GB
Dell Precision T3500
Intel(R) Xeon(R) CPU W3540 @ 2.93GHz (8 CPUs), ~2.9GHz
6.00 GB RAM
Windows Vista™ Ultimate (6.0, Build 6002) Service Pack 2
NVIDIA Quadro FX 1800 8.17.0012.5849
Valued Contributor
Deadhorse
Message 4 of 6 (153 Views)
01-29-2010 11:52 AM in reply to: Deadhorse
I tried a contured flange and when I tried to flat patter I got, errors ocurred during update. Could not build asmflatpattern. No base plane found.
What did you mean by select the face first?
Valued Contributor
Deadhorse
Message 5 of 6 (153 Views)
01-29-2010 11:57 AM in reply to: Deadhorse
I got it, thanks. But why with this feature/part do you have to select the face first?
Valued Mentor
delineryan
Message 6 of 6 (153 Views)
01-29-2010 12:00 PM in reply to: Deadhorse
Inventor needs a fixed face as a base point for all the flattening and folding, sometimes, when it isn't and obvious face then you have to tell inventor which face is the base.
If that makes any sense.
I guess it could just ask you to pick a face every time like some other programs...
Ryan
Ryan
Inventor Version:
6.00 GB RAM
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
