Inventor General
Message 1 of 3 (136 Views)
Units setup
136 Views, 2 Replies
09-26-2013 07:32 PM
Is there a method to change how units are displayed?
For example, instead of showing 4 mm,  I want it displayed at 4 MM.
Distinguished Mentor
pcrawley
Message 2 of 3 (121 Views)
Re: Units setup
09-26-2013 08:47 PM in reply to: dimasilang
In a drawing - or in a model?  If it's a drawing, just create your own suffix and hide the unit string.
To be technically correct however, under the SI units definition, "milimeter" is abbreviated to "mm" not "MM".  The first letter prefix "m" in lowercase means milli or 1/1000th of [unit of measure].  "M" however means "mega", or 1000,000 times [unit of measure].  So by writing "MM" to represent millimeters, you might end up with something rather larger than you expected.  (Not sure if "M" is even a recognised unit of distance?)
http://en.wikipedia.org/wiki/SI_prefix#List_of_prefixes
Good example: 1Mm³ means one cubic megametre, or the size of one cube of 1000000m by 1000000m by 1000000m
Not the 1mm³ you might have got if using the correct case on the unit string.
Peter
Message 3 of 3 (95 Views)
Re: Units setup
09-27-2013 02:16 AM in reply to: dimasilang
Hi!
Like someone said before, don´t mess with units...
You will produce documentation with bad information...
Regards.
CarlosC
Autodesk Factory Design Suite Ultimate 2014
Autodesk Simulation Mechanical
Autodesk Simulation CFD
Windows 7
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
