Inventor Forum
Units setup
2 REPLIES 2
dimasilang
285 Views, 2 Replies
Units setup
Is there a method to change how units are displayed?
For example, instead of showing 4 mm,  I want it displayed at 4 MM.
2 REPLIES 2
pcrawley
in reply to: dimasilang
In a drawing - or in a model?  If it's a drawing, just create your own suffix and hide the unit string.
To be technically correct however, under the SI units definition, "milimeter" is abbreviated to "mm" not "MM".  The first letter prefix "m" in lowercase means milli or 1/1000th of [unit of measure].  "M" however means "mega", or 1000,000 times [unit of measure].  So by writing "MM" to represent millimeters, you might end up with something rather larger than you expected.  (Not sure if "M" is even a recognised unit of distance?)
http://en.wikipedia.org/wiki/SI_prefix#List_of_prefixes
Good example: 1Mm³ means one cubic megametre, or the size of one cube of 1000000m by 1000000m by 1000000m
Not the 1mm³ you might have got if using the correct case on the unit string.
Peter
CCarreiras
Hi!
Like someone said before, don´t mess with units...
You will produce documentation with bad information...
CCarreiras
