"Kevin Wehner" <kevinwehner @ zoominternet . net> wrote in = message=20 news:40928274$1_3@newsprd01...>If IV is going to correctly add = or multiply a=20 mix of milimeters and inches, it has to know how the units relate to = get a=20 final number.Mixing inches & millimeters = should be an easy=20 calculation requiring no input on the users part (except adding the = suffix).=20 The value returned should be in what ever units are set as standard=20 & should be able to be changed by the user.>If IV is expecting 'in' and gets = 'hp' it=20 won't have an established relationship between the two to give = you the=20 correct value.In which case, a simple dialog box = "Choose which=20 value to consider unitless" would fix the problem.------=_NextPart_000_000D_01C42EA8.A172DF60--
Goodmorning
I'm Alessandro F. new in this Forum.
I've a problem with unitless parameter.
Imy standard and my model parameters is in "mm" but when insert a personal parameters "Unitless" linked ti model parameter in "mm" return a value 10 times small:
ex:
L_bar (mm)=1890mm
test (Unitless)=189
how can set the value of "Unitless" equal my "mm" parameter?
many Thanks
ALessandro
You have replied to a thread that is 10 yrs old.
You can assign the units.
Attach your file here.
