I am cleaning up an old workstation in preperation for installing PDS 2012. I have been able to remove everything execpt Design Review 2010. I get an error about needing Visual C++ 2005 Service Pack 1 Redistributable Package to be installed.
I have tried installing this package, that did not help.
I see that Design Review 2012 has a hot fix for this issue. Is there one for 2010? or can I install 2012 over my broken 2010 install and will that cause problems later?
Steve Walton
Solved by VinodBalasubramanian. Go to Solution.
Below blog article has a suggestion on doing a clean uninstall of design review,
http://dwf.blogs.com/beyond_the_paper/autodesk-design-review/
Hope it helps. Let me know, if the issue persists.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
