Inventor General
New Member
Zaira_engineer_SAE
Message 1 of 3 (303 Views)
Unfolding/ripping round tubing with both ends notched
303 Views, 2 Replies
02-22-2013 05:34 PM
Hello everyone
I have been trying to unfold round tubing made through the frame generator.
Here are the steps I took:
1. Used Frame Generator
* both ends of the tube are notched
2. Opened part and converted into sheet metal
3. Used the following tutorial:
http://forums.autodesk.com/t5/Autodesk-Inventor/Unfold-a-tube/td-p/3168764
4. Was not working so I drew sketches on both ends of the notched tubing and added points
5. Used rip tool (point to point) and did not work
* I made sure the thickness was the same
I thought I was doing something wrong so I generated a new round tubing frame with only 1 end notched and the other end flat and followed the tutorial. IT WORKED!
I have came to the conclusion that you can not use the rip tool on tubing that has both ends notched.
Is there a way where I can cut the tubing in half so I have 2 individual pieces/files of tubing with 1 end flat and 1 end notched?
Thank you
Distinguished Mentor
rdyson
Message 2 of 3 (275 Views)
Re: Unfolding/ripping round tubing with both ends notched
02-23-2013 06:44 AM in reply to: Zaira_engineer_SAE
Create the rip before the first split, but the flat pattern will be next to useless.
JDMather
Message 3 of 3 (260 Views)
02-23-2013 12:06 PM in reply to: Zaira_engineer_SAE
How will the part be manufactured?
In the flat pattern will the cut edges be perpendicular to the flat?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
