So, I currently have an unfold rule that works for all the different kinds of angles I could ask for, however, I would like the value of that Custom Equation to be reported to Parameters or on my drawing. Is there anyway I can get Inventor to report that value through iLogic or something similar to that?
Here's an iLogic rule that will get the last (or the first if there is only one) equation of the active unfold method. It will assign the equation to a custom iProperty named UnfoldEquation. You have to create this iProperty before adding the rule. Note that if you have more than one equation, you might need more properties. You can use the iProperty in the drawing. I don't know if the equation will be in the format you want for the drawing.
I tested this in Inventor 2011. It should also work in 2012.
Dim partDoc as PartDocument = ThisDoc.Document Dim sheetMetalCompDef As SheetMetalComponentDefinition = partDoc.ComponentDefinition Dim oUnfoldMethod As UnfoldMethod = sheetMetalCompDef.UnfoldMethod Trace.WriteLine ("Unfold Method: " & oUnfoldMethod.Name) Trace.WriteLine (" In Use: " & oUnfoldMethod.InUse) Trace.WriteLine (" Up to Date: " & oUnfoldMethod.UpToDate) If (oUnfoldMethod.UnfoldMethodType = UnfoldMethodTypeEnum.kCustomEquationUnfoldMethod) Then Trace.WriteLine (" Unfold Method Type is Custom Equation") For i As Integer = 1 To oUnfoldMethod.EquationCount Dim equation As String Dim minimumValue As String Dim minimumCompareCondition As ComparisonTypeEnum Dim boundedVariable As String Dim maximumValue As String Dim maximumCompareCondition As ComparisonTypeEnum oUnfoldMethod.GetEquation(i, equation, minimumValue, minimumCompareCondition, boundedVariable, maximumValue, maximumCompareCondition) Trace.WriteLine (" Equation: " & equation) iProperties.Value("Custom", "UnfoldEquation") = equation Next Else MessageBox.Show(" The active unfold method is not a Custom Equation.", "Sheet Metal") End If
