Inventor Forum
Undocked browser behavior - Inventor 2014 + Windows 8
5 REPLIES 5
nmunro
459 Views, 5 Replies
Is anyone else seeing this? Open Inventor and a document and move it to your second monitor. Drag the browser away from the edge of the Inventor window until the outline appears as a separate window (undocked). When you release the mouse button does the browser jump back to the first monitor? Can you drag it onto the second monitor without docking it back in the Inventor window?
Neil
https://c3mcad.com
5 REPLIES 5
Davarn-Tool&Die
in reply to: nmunro
Yes, This is simular to the problem I had a year ago. I went to my Video Card setting and turned off "Dialog Repositioning".  For the AMD FirePro Control center, go to Desktop management and unclick the desktop box.
Good Success to you.
If this helped, please mark as solution or give Kudos, or both!
David Arnold
Designer-New Dies
Motor City Stamping Inc.
(Desk: 586-949-8420 Ext. 184
+Email: darnold@mcstamp.com
" www.MCStamp.com
nmunro
in reply to: Davarn-Tool&Die
Thanks David but that is not the solution. Dialogs, for example the Extrude dialog box transfer without issue, it is only an issue with dockable windows in Inventor (i.e the browser). It is an AMD Radeon 6470M card in an HP8460 laptop.
https://c3mcad.com
Sergio.Bertino
in reply to: nmunro
Spoiler
Unfortunately I cannot replicate the issue on my machine, everything works fine as expected. Maybe there is some setting in you graphic card that make this behavior happen. I would suggest to update your graphic card drivers and/or check if there is some strange settings activated in the graphic card control panel.
Sergio Bertino
MFG Technical Support Specialist
mrattray
in reply to: nmunro
I see the opposite behaviour. When I try to dock to the edge of the second monitor it jumps back to the primary. I have to "fake it" by undocking it and placing it near the edge.
Mike (not Matt) Rattray
rdyson
in reply to: mrattray
Mike (not Matt)
I find it easier to place the browser if I reduce to window the primary IV window. That keeps the browser from trying to re-dock itself.
PDSU 2016
