I was a long time SolidWorks user until a month ago when the company I work for moved to Inventor. I started using Inventor and so far I like it but I have a few questions about using ABA/Macros, which is one of the options I think I will enjoy the most since I have a little bit of experience in the programming world; I know a little bit of C++, Objective-C, Javascript and Ruby.
Here are my questions.
1- Where can I start learning about VBA?
2- When you use VBA within Inventor, is this considered a macro, a plug-in or you are just scripting?
3- What are the supported languages and which is the most widely used?
4- Where are the APIs to interact with Inventor?
Can some one direct me to where I can read more about this concept in general?
Thanks a lot.
Solved by mrattray. Go to Solution.
Welcome to the forums and Inventor.
There is a separate forum specfic to the VBA side of Inventor here:
http://forums.autodesk.com/t5/Inventor-Customization/bd-p/120
The sticky links to a great tutorial "My First Plug-in Training" about that side of things:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=17324828
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Hi fsdolphin,
In addition to the information the others have provided, here is an additional link that covers this subject pretty well:
Autodesk Developer Network
http://usa.autodesk.com/adsk/servlet/index?id=1079044&siteID=123112
Of particular interest to you might be the "Porting your application from SolidWorks to Autodesk Inventor?" section at the bottom of the page.
I hope this helps.
Curtis
