Inventor Forum
Unable to split solid
9 REPLIES 9
Message 1 of 10
BarryZA
585 Views, 9 Replies
Hi Guys
I have been splitting up these profiles into multi-bodies for a couple of days now, and all of a sudden I get an error "unable to split solid"
I want to split the centre solid on the extruded surface that is visible.
Still on Inv 2013 I am afraid. 2015 sitting on top of my machine at the moment.
Any and all help appreciated.
9 REPLIES 9
Message 2 of 10
admaiora
in reply to: BarryZA
"045 TAG 50 cross sections master.ipt"  missing
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 10
BarryZA
in reply to: admaiora
i've supressed the link to the derived part
Message 4 of 10
CCarreiras
Hi!
Sorry, but Without the "045 tag 50 cross sections master.ipt", this file you place in attachement is useless.... it's like you send a IAM without the parts...
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 5 of 10
admaiora
in reply to: CCarreiras
At a first look to many useless features. Split, mirror, split, mirror,split...all in the same place and often ciclyng depending eachothers..and obtaining the same results.
To straigth split you don't need to create a surface, you can use directly the sketch.I think that with a "clean" featured part you will have no problems.
Admaiora
Message 6 of 10
BarryZA
I'm sure you are correct. But you know what it is like, when you are in a hurry something has to go wrong..
Message 7 of 10
admaiora
Absolutely my friend.
Admaiora
Message 8 of 10
CCarreiras
Hi!
I found the issue...
You have "loose" solids ... these two portions of solid are disconected from the main body, and this cause the issue...
If you delete, (or split) these "disconected" solids first, you are able to split the main body in two by the extrusion.
Just to confirm, If you suppress the delete operation... split solid doesnt work, (image below)....
....and that's it...
CCarreiras
Message 9 of 10
BarryZA
done! many thanks Carlos.
Message 10 of 10
WHolzwarth
Split feature dosn't work with different lumps. See picture. You have created two islands (red) with Split6.
Solution:
a) Change follow-up of Splits
b) Extrude again two "bridges" to the islands, do the Split, and after that delete the bridges by delete face with healing.
Well, Carlos explained it in the meantime, too.
Walter
Walter Holzwarth
