Inventor Forum
Unable to save STEP file
13 REPLIES 13
Message 1 of 14
nstalker
1881 Views, 13 Replies
I ran into this problem today.  It only happens with this one file so far.  It is a STEP file.  I open it in Inventor and then when I hit save it gives me an error.
The system cannot find the path specified.
The database in C:\Users\nstalker\Documents\Inventor\DesktopAssetCreation2\Imported Components\C731222M-U2 \68514423656.ipt could not be saved
The database in C:\Users\nstalker\Documents\Inventor\DesktopAssetCreation2\Imported Components\C731222M-U2 \11505_3.ipt could not be saved
etc. etc. etc. for every single part
I have tried to save it on two different computers with two different projects and I get the same error.  Any ideas?  I have never ran into this problem before and I open and save STEP files often.
13 REPLIES 13
Message 2 of 14
JDMather
in reply to: nstalker
Can you zip and attach the original STEP file here?
Not sure if this would have anything to do with it - but do you have the Options set to NOT create a translation report?
Can you post a screen shot of you Options?
Message 3 of 14
nstalker
in reply to: JDMather
I'd like to but it is proprietary.  What would you be looking for if you opened the STEP file?  Just wondering to see if it's something I can look for.
Message 4 of 14
CCarreiras
Hi!
Never happened to me, but...
When open the step, go to options and select the option to save the files during migration... it's just a guess... or try other preferences,  good luck
Regards.
CCarreiras
Message 5 of 14
JDMather
The Options.
If that didn't reveal anything I might then try opening the STEP in Notepad and take a look around (not sure if that would reveal anything).
Message 6 of 14
nstalker
thanks for the responses.  I think the STEP file is OK because I am able to open it and everything comes through.  I just can't save it.  I tried going into the options selecting the checkbox that save components as it creates them but it creates the first component then gives me the message that it can't save it and then repeats that for every component.  I've tried saving it inside and outside of the project.
At the moment I'm trying a different route.  I've opened the STEP file in NX and I'm exporting it to a parasolid and then I will try opening it in Inventor and saving it but it's kind of lame if I have to do that.
Message 7 of 14
JDMather
Does it pass quality check (green checkmarks)?
Can you post a screen shot of the Inventor browser?
I'm wondering about a special character in filename(s).
Also, did you try a File>Save Copy As?
Can you right click on each part - Open and try to Save Copy As individual parts?
Message 8 of 14
nstalker
Should I select "Check Parts during Load"?
Message 9 of 14
nstalker
Here is a screenshot of the browser bar
Message 10 of 14
nstalker
It worked when I opened the STEP file in NX, exported a Parasolid, and then opened the parasolid in Inventor.  Inventor allowed me to save the parasolid.
Message 11 of 14
CCarreiras
HI!
Maybe because the NX is a powerfull program to work with surfaces.... and solve lot's of issues than Inventor and others can't do.
Regards.
CCarreiras
Message 12 of 14
BarryZA
I have spent the week trying to save files that I imported from a .step file into Inventor, and then had to save as .stl (don't ask).
What I noticed is that Inv will only let me save the files if they are solids, it refuses to save the ones that came through as surfaces (due to open loops etc.). I noticed in your browser that you have a couple of surfaces, maybe they are holding you up as well.
Message 13 of 14
KevinLi-Autodesk
Hi nstalker,
From your screenshot I guess your STEP file name is "C731222M-U2 .stp ", please try to remove the spacebar in its file name to "C731222M-U2.stp" and have a try.
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 14 of 14
nstalker
in reply to: KevinLi-Autodesk
thanks for the suggestions - I will come back to this if I run into this again.
