Hi Andrew,
I have remodelled the Master file and it works now. I have removed the first
Cut in both models and have created a gap by revolving each of the cone by
an angle instead. Similar to what Jeffrey suggested in his post. The reason
why I didn't go with the Revolve by an angle in original file was my attempt
to keep the gap width uniform across the face of the cone. But if the gap
width is not an issue here, then Revolve by an angle is a go.
Needles to say, that I was not able to use Rip feature on the Branch. It
kept on failing on creation. Same is true for the large cone when trying to
make a Rip across the cut out. I am still puzzled why Refold didn't work in
the original version of the model. Too many questions as you can see
Thanks for looking at my website. Yes there were some interesting projects
in the past. The robotic Loss on Ignition analyser was designed in IV7. And
then I machined all mechanical components except the encoder disks for that
system. Look forward to get involved with something similar in near future!
Best Regards,
Igor.
Web: www.meqc.com.au
www.boatworks.meqc.com.au
wrote in message news:6289195@discussion.autodesk.com...
Hi Igor,
I have come to the same conclusion. A little disappointing but then, i
think this tool is new with Inventor 2010.
BTW, I checked out your website... looks like you guys do some interesting
work.
Andrew
