Inventor General
*Strenk, Jim
Message 1 of 6 (77 Views)
Unable to import Inventor 6 (SP1) SAT file into AutoCAD 2002
77 Views, 5 Replies
11-22-2002 12:47 PM
Inventor 5.3 SAT files can be brought into AutoCAD 2002 drawings, but not
Inventor R6 or SP1 SAT files. AutoCAD complains about either file version
or file type.
Is there a workaround, or must this issue be addressed with a Service Pack
or R7?
*darvinv
Message 2 of 6 (77 Views)
Re: Unable to import Inventor 6 (SP1) SAT file into AutoCAD 2002
11-22-2002 12:57 PM in reply to: *Strenk, Jim
In "save copy as" dialog, click on options, turnversion down
to 6.
darvin
*Zander, Quinn
Message 3 of 6 (77 Views)
11-22-2002 01:01 PM in reply to: *Strenk, Jim
Jim,
Once you specify the filename, hit the options button in the save dialog
and bump the SAT version down to 6.0.
QBZ
"Jim Strenk" wrote in message
news:97085A43CCDA4DA9633F9A25577A4728@in.WebX.maYIadrTaRb...
not
version
> or file type.
Pack
> or R7?
*Strenk, Jim
Message 4 of 6 (77 Views)
Re:
11-22-2002 06:59 PM in reply to: *Strenk, Jim
By "turning it down a notch" aka a reverse Emeril Lagasse, did the trick. I
would imagine that future versions of AutoCAD will incorporate a newer
version of the ACIS Kernel, no?
Thanks Quinn and Darvinv for your replies!
"Quinn Zander" wrote in message
news:A4FAE1685B26FBFD5A4CE8389E384CED@in.WebX.maYIadrTaRb...
> Jim,
> QBZ
*Fulford, Drew
Message 5 of 6 (77 Views)
Re:
11-23-2002 01:18 AM in reply to: *Strenk, Jim
I would guess new acads will read SAT 7 since they are built on new ASM
kernel which was founded on ACIS 7. But beyond 7 it wont be called ACIS
(SAT) as adesks licencing of acis stopped at R7. I have no idea if there
will be a new exchange format developed for ASM as it moves forward. Imagine
if autodesk set a standard for fully featured exchange.
- drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
news:CF3C4E97A5B4514FB9BCBCCA4E47D96C@in.WebX.maYIadrTaRb...
I
> > Jim,
> > QBZ
*darvinv
Message 6 of 6 (77 Views)
Re:
11-23-2002 02:34 AM in reply to: *Strenk, Jim
drew,
Isn't that where Open Step and Open CNC are supposed to
be taking us? What would be wrong with co-operating with
those efforts?
darvin
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
