I am able to extract an flat pattern (for round to square) but not exactly as the customers drawing.
The original drawing shows some relief in bending lines which i am not able to add in inventor.
after a glance at the attachments you will clearly understand what i want.
Thanks in advance
Solved by yannicknielsen. Go to Solution.
Hi!
Without the 3D Information we can't do almost nothing to help.
Thanks for quick reply & sorry for delay from my side.
Attached you can find the 3D deg.
When I see your post, I understand that you want some "space" between the bend lines in the corners.
It can't be round AND made with that relief, though - That would be square with a nice round corner instead, so why do you want it as the customer's drawing?
Unless the customer has produced a drawing specifically for your workshop, you cannot rely on the measurements from that drawing.
I would suggest that you tell the customer that his drawing will result in a square with with big round corners, and ask if that is what he really wants.
If you want a result like his, you'll have to draw half a square instead of half a circle for your second sketch, and then add fillets (although those don't have any dimensions)
