Attached is the model in IV14. I am not able to make Fillet5 listed in the browser properly. When I used Extrude, it cut through the body.
Solved by JDMather. Go to Solution.
This is a strange one.
I change only changed the order and it worked?
Hi luiww,
Thanks for reporting this, we'll look at correcting the behaviour and I've logged DID 1516908 for reference.
Walter, JD - thanks for the workarounds.
Best wishes,
Indy
